EV's are far more polluting than ICE vehicles.
Here is a little facts that the Idiots in charge do not talk about:
Then there are the hidden costs, the costs you have to dig a little deeper to find. For example, for
each EV auto battery, one must process
25,000 pounds of brine for lithium, 30,000 pounds of ore for the cobalt, 5,000 pounds of ore for the nickel and 25,000 pounds of ore for copper. When it is all added, you dig up
500,000 pounds of the earth's crust for just ONE battery.
Let's examine the mine at Jiangxi, China.
The workers use ammonium sulfate poured into big holes to dissolves the clay. The strong ammonium fumes are very damaging to the lungs of the workers, but that is par for the course for
Chinese treatment of laborers. Using a number of other noxious, toxic, cancer-causing chemicals, the sludge is processed to remove the just
0.2% rare metals, with the remaining 99.8% contaminated toxic material being dumped back into the originally created hole. It is stated that, "
many of these rare earth mining processes also unleash plumes of sulfur dioxide," a toxic gas, into the atmosphere. Of course people have concerns for aquatic life in nearby rivers and streams.
Then there is all the lithium that you need. One of the places for obtaining vast amounts of lithium is the
Atacama Desert in Chile. This area is filled with subterranean aquifers, which are reserves of fresh water. They need lots of brine (salt water) to refine the lithium, but that is no problem, for they have discovered salt water brine below the fresh water aquifers. So in an area where fresh water is precious, they are jeopardizing the fresh water system by drilling through it to get to the needed brine, so we can make our EVs to save the planet. It is stated that there is a weight of evidence, such as "
shrinking pasturelands, failing crops, disappearing flora and fauna," that all point to a process of desertification, which is being exacerbated by lithium extraction. It is stated, "
the impact of disturbing a 'huge complex hydrological system' is not visible from one day to the next," but the lithium mining and the desertification "
are interlinked without any doubt."
