Last week eastern Iowa and western Illinois got pounded with a major rain event. There were rain gauges at work that were spilling over at 6". The parking lot took the most water, naturally right, there were cars that were completely submerged, it was a really bad deal. I just happened to park where the water was at its lowest, which was up halfway on my fog lights. HRNT is stock, no lift, 31"x10,50" KO2's.
So anyway, I didn't initially think the Jeep was damaged, until the next day I smell shit inside. I pulled up the carpet to see some dampness on the tub and a little bit of water, only on the passenger side in the front. I cleaned it up and aired it out overnight. What really surprised me was to see how much rust is under there, that's a seperate issue now.
My front ring and pinion has been leaking for quite some time. Is there a possibility that water could seep into the differential thru the bad seal? My Jeep has developed a "whine' on decelleration since the flood. Also, the brakes are now squeaking, loud, when I release them, they only does this while in gear. I can pump the brakes all day in nuetral and not hear the squeak.
My employer is really making it right with the employees. They are paying all deductables, and paying for the damage, plus a rental if you needed one. It's been estimated at a million dollars in vehicle claims. My Jeep goes Monday to get looked at, what should be looked at most closely by the shop? This will have to be turned into my insurance, and I'm afraid if I ever try to sell it, that it will be marked flood damge and substatially lower the value. Is this true?
All in all I got lucky, lots of people's basements & quite a few business's were completely destroyed by flood waters. Mine, thankfully was not. @Northwood can probably attest to how much rain swept thru the area in that 24 hour period, it was insane.
Thanks for reading fellas.
