Fog lights plug
Scott Davidson
Banks county Ga
I have a 2000 tj, and under the front fenders at the front marker lights there is a little plug at the end of a wire that i believe is for a fog light. There is one under each side. These have the factory plug. The lights on the front bumper do not have the correct plug that will fit.I have tried to find this plug that fits but it seems that you can only get it at the end of a factory set of the lights. I refuse to pay that much for a set of lights. Dose anyone have a set thts used or the plugs they would sell or any ideals of where i may get a pair of the plugs to put on my lights. Thanks in advance. Scott
So, then the fog lights will be controlled by the multi function turn signal switch. Also, the fog lights will turn off with high beams.
Reactions: Scott Davidson
