- Price
- $100
- Location
- North Versailles, PA
I am selling a Ford 8.8 rear end from a 2007 Ford F150 XL 2WD. I recently swapped it for a Ford 9.75" rear end, so I cannot send it in as a core.
The ring and pinion has significant slop, which is the reason it was removed. It will have to be regeared. It still has the worn out factory 3.55 gears and a worn out limited slip. (The limited slip is no longer functional, and the differential acts as an open differential.)
It has axle shafts with a 6X135mm lug pattern. It will come with shafts, all internals, lug studs, parking brakes, and rotors (rotors are a bit rusty). ABS sensor is included.
The 8.8 is the one on the right (on blocks) in this picture. It will come complete as shown plus rotors.
Due to its size, I cannot ship it. Price is negotiable. If it does not sell, I will scrap it.
