I've been researching the numerous choices in front axles swaps, and wanted to gather others inputs. The goal with this setup to to drive way too many miles. Hopefully at least 200k+ both on and off road across all types of terrain and back country.
My current long term build plans are:
Thanks for your time!
Dale
- Diesel engine swap, looking for a good deal on an Isuzu 4BD1T with likely a 700R4 or 4L60e.
- Transfer case to be determined but might stick with upgrading my NP231J or if a NP241OR makes itself available for a reasonable price I'll buy that.
- I don't plan on going over a 35" tire size anytime in the future with this rig. I may entertain 37's one day but nothing more. This means lower gear options.
- Suspension will be modeled after the Savvy midarm kit. I would buy the kit, but want the experience of making one myself. I'll be studying up on suspension dynamics and probably trying to copy Blaine's dimensions. I also have my own lathe and tools to make a number of the components myself. Too bad they don't sell schematics!
- Selectable hubs on the front are mandatory. I might even convert to full floating in the rear with flanges.
- DIY highline fenders to help keep low center of gravity.
- DIY big brakes.
- Possible coil-overs if suspension needs warrant it.
- Keep a close to factory track width. I currently have aftermarket wheels with 31x10.50R15 tires that stick out slightly from my aftermarket fender flares. Being in Oregon we have four seasons and weather and I'm going to keep it street friendly. Stepping up to 12.50 width I might get a wheel with a larger backspace to keep the tires under the flares.
- Build the HP 30 housing I have from an XJ non-disco model. I could purchase and utilize the REID 33/44 upgraded knuckles to achieve hubs and bigger breaks, but I don't have the option of anything lower than a 5.13 and the ring gear is smaller at 7.12". This would make an easy install initially but not so important with a future three link. I have no doubt with sleeves and a truss it'll be as strong as a I need.
- Find an older ford HP 44 and narrow it to match the factory WMS-WMS of 60.5". If I found a '78-'79' HP 44 from an F250 it would have 3" tubes at 0.5" wall thickness. This would be plenty strong, have the gear options, brakes, and hubs, but these are increasingly hard to find and getting more expensive. I could still do the same with a F150 or full size Bronco or Jeep and achieve all the same. With narrowing, an axle with a cast wedge might even be viable. I could cut the wedge out and narrow at that location using a sleeve to keep everything straight?
- Used Jeep Rubicon axles are still available, but I'm throwing away mostly everything but the housing to achieve my goals listed above. Doesn't seem worth it for the price they're going for.
- JK axles are likely too wide. I've done some measuring and they would fit with the stock 7" backspacing wheels, but as soon as I go wider tires and wheels it'll push the tires outside of the flares. I might be able to make this work, but they are still cost prohibitive.
- Aftermarket housing and add the outers from an older Ford/Chevy Dana 44 for the hubs and brakes. This option and any other variation of build and buy seem to be spending around $2,000 on just the housing even with buying a center and building everything else. Not to mention locker, gears, and axle shafts.
Dale
