Front driveshaft u-joint removal
Mine had the injected plastic on the front drive shaft, but not the axle shafts. Was that a thing that was done?
I used MAPP gas and a ball joint press the rebuild the drive shaft. The first u joint was daunting and pretty noisy when it popped.
@jjvw
I have that too on my LJ, I thought it was just me. I got the injected plastic completely out, but I am at a loss as to how to get a new joint in there...the injection channel is set too far in to allow for exterior clips and I don't see any ledge on the inside of the ears to put an inside clip in...if you could solve this mystery I would be thrilled.
It works as designed.
From your other post.
'I got that far, but I'm at a loss as to how to get a new 1330 u-joint in there'
Is 1330 the right joint for that location?
My notes on the stock Rubicon u-joints...
Front Drive Shaft (stock)
-U-Joint @ Diff: Spicer 5-793x
-U-Joint @ DC Joint (x2): Spicer 5-790x (5-1330X)
-Non-Greasable Centering Yoke Spicer 211996X
-Centering-ball Seal: Spicer 2-86-418
-U-Joint Strap Kits Spicer 2-70-18X
-T-case Bolts 6036415AA
Rear Drive Shaft (stock)
-U-Joint @ T-Case: Spicer 5-795x
Front Axle shafts (stock)
-U-Joints: Spicer 5-760x
I have mine listed as 5-760x for all Ujoints on the front drive shaft. '06 Rubicon TJ. That's what I got from the "sticky" page. All other joints are same as you listed.
Always ask for ALL of the old parts back from any job you don't do yourself. Tell them you want them for "back up spare parts". And anytime they pad the bill "oh yea, had to build a special tool..." ask to see this "special tool" so you know what you'll need next time.
Reactions: Marklar1983
Thanks to everyone for the help. I found an old page that listed out all the u-joints, and as the chart from @jjvw shows, the 5-793x is the proper u-joint for the location in question. I got a spicer on the way from advance auto, using their 20% off and free shipping over $25, I got one here by the end of the week for $27 total.
