AmenThis is good insight...I believe this is true for steering, etc as well. With random parts and alignments done the possibilities of weirdness are almost infinite.
The fact that you think this way makes me trust your opinion more (for Jeep stuff, not politics ).Interesting! It worked well for me, but the placebo effect is also a powerful thing as well, so it’s hard to say objectively how much it actually did and how much was in my head.
I wouldn't say its normal, but it is common. Mine would pop out of reverse when you'd start moving. I replaced it (back in 2013 before I knew any other method) with a new MOPAR unit. drove first 1000 miles with conventional oil, then swapped in synthetic... I think it was Royal Purple, not Redline MTL. not a hint of issue since. The swap was done at about 118k miles, and we are at almost 130k now.This is normal behavior for the 6-speed transmission. You have to finesse it when going into reverse, trust me (I've owned one).
That and Redline MT-90 makes a huge difference in them with the way they shift.
MT-90 or MTL?This is normal behavior for the 6-speed transmission. You have to finesse it when going into reverse, trust me (I've owned one).
MT-90 for NSG-370MT-90 or MTL?
I hope MTL, because I just bought a gallon of the stuff based on this post:
Neither will hurt but I was running MT-90 in mine.MT-90 or MTL?
MT-90 for NSG-370
Idk why I thought it met that requirement. I guess I missed that detail when changing my trans fluid since the mt90 was recommended so frequently. It seemed to make a difference but my then new to me 6 speed was probably overdue for a flush anyways. Ill have to try mtl next time to compare them.Chrysler calls for MS-9224 for the NSG370.
MTL meets that specification.
MT-90 either does not, or has not been evaluated against it.
MT-90 may do just fine, but MTL is the official application.
I doubt the bump in viscosity would hurt anything. No idea what might be different in the additive package though.
I'm comfortable with my purchase of MTL.
Or disassemble the console.. I had console out already when I filled my new trans, so I just added through the gear shift opening. (was really easy to pour from above)I needed just a hair under 2 qts. So be sure to have that 2nd full qt handy. Also always make sure the fill/check plug can be removed before you open the drain plug. It'll suck finding out after you drain it that you can't get fluid back in!
How can that be better than having it in neutral before reverse? Those who have used non synchro boxes would understand this I believe people are to eager to get it from gear stop 2nd to reverse. maybe because I have been driving stick shift all my life I dunno? lolI’m a fan of sticking it in second before reverse...every time. A guy said it stops the synchro movement that engine pulses cause ..I don’t know if that’s true, but it helps with grinding reverse.
It's better because is prevents grinding.How can that be better than having it in neutral before reverse? Those who have used non synchro boxes would understand this I believe people are to eager to get it from gear stop 2nd to reverse. maybe because I have been driving stick shift all my life I dunno? lol
I get zero grinding when shifting to any gear. But then I replaced with a brand new crate trans back in 2013...I keep hearing about this reverse grinding issue with Jeep 6 speeds. I want to make sure I understand. Are you guys telling me reverse is synchronized and won't grind going into reverse when everything is working properly? And shifting into a forward gear before shifting into reverse is not something normally done?
Just curious.....but Jerry Bransford has always post Redline MTL.....not Redline 90. The MTL is what I put in mine and it made a difference. Not a placebo....You either grind or you do not grind. I put mine in and a week later I go and did a good test run thinking about it and no grind etc.I'm not suggesting it hasn't done something for someone...but if people want it to be good unless it destroys the tranny it must be working wonders.
Having said that people make the mt-90 out to be some magical fluid for the getrag and it certainly is not. My experience with it was no change and possibly got a tick worse in some. In customers that wanted us to switch their tranny fluid to that stuff the only positive we've noticed was if they were over due for a fluid change in the first place in which I can't award redline a trophy for that. Perhaps to them there was a change and if they think so that's great. I've no vested interest in it other than customer satisfaction. If vegetable oil was a known good getrag lube we'd be advising the customers to switch over to that...for a charge of course .... but none the less we want customers to come back.
If the motorist wants to believe something will work and it hasn't made anything worse it is a win in their eyes.
You can put pixie dust in the Getrag though and it's still a miserable behaving SOB. Reverse is an adventrue. 1st thru 4th is notchy as hell. Maybe not all 4 gears but 1-2 or 2-3 or 4-3 ...
Speaking of notchy though...I swear the prerequisite for Jeep awarding a manual tranny contract to someone is it must be notchy. The AX-15, Nv3550 I swear more are notchy then aren't...although to a lesser degree than the 370...and they don't share the reverse debacle of the getrag.
That and the ax-15 and NV3550 were not car transmissions either. The Getrag is brought to you straight from the little old Chrysler Crossfire. (among others as well)
Even after the update to the reverse situation most still act finicky in reverse. Same old shit. Not going in...jumping out of reverse mid backing up, notchy, flat out grinding getting into a specific gear...
