Hey All!
I recently bought my first Wrangler, a 2005 LJ, and I'm working on getting some of the kinks worked out from the previous owner.
My first couple of projects involved upgrading to the ZJ steering components, getting it aligned, and replacing the track bar and dampener to try and get rid of some god awful creaking when turning the steering wheel. Now, with that all resolved and everything looking like it was in good shape, I got myself some new wheels, got them balanced, but much to my dismay, I can't get the truck over 65 miles an hour without it shaking itself apart.
From what I've read and seen, I'm having trouble discerning the root cause. I don't feel it much in the steering wheel, more in the feet, and there are differences between vibration on and off acceleration. The truck has a 4" Pro Comp (K3083B) lift that I I've been working on replacing components on as well; I have removed the drop track bar mount and returned it to stock, and then replaced all four shocks with Ranchos. I originally greased the OEM bolt that holds the track bar in place but I have a replacement ready to drop in next time I get under the truck. My ball joints appear to be in good shape, unmoving in North/South and East/West wiggletesting. Finally I aligned the truck using the bar method with an 1/8th" toe in per recommendations I have here on this site.
Where would you look next? Perhaps the driveshafts / differentials?
Since this is a 4" lift from the previous owner I'm not sure if care was taken to ensure correct pinion angles.
