Regarding the Tcase, are the spacers of the skid plate the same mechanism in which the tcase itself is lowered? IE, is the tcase bolted to the skid an the spacers simply angle the powertrain by a few degrees? Wild.
On the Driveshaft - I'll do some research on the process to install the SYE, I'm no stranger to diving in so unless there are some wild specialty tools required I should be able to handle that, though to confirm, only the rear DS needs to be swapped with a DC because the front already has one, yes?
For for the control arms, would it be sufficient to purchase only lower adjustable arms and leave the top stock ones in place? or would adjustable uppers and keeping the modified lowers be appropriate?
And wow I didn't even notice that those were relocation brackets for the shocks. Those must compensate for the wonky axle angle. I did just purchase a set of Rancho RS5KX's for the appropriate lift height so those should just slot into place, since the ones that came with the lift were completely blown (shocker).
Thanks, I feel like this is likely the true culprit here.
