Hello,
I purchased my 2001 Wrangler Sport with a 6" lift and 35x15 Super Swamper TSL's. This was purchased with the intention of downsizing the tires and lift and using it for family fun and also some hunting trips. It will spend more than 99% of it's time on paved roads and I have zero intentions of ever doing any rock crawling or serious off-roading.
The Jeep will probably see 3k miles per year or less. I really want to run 33x12.50 tires on 15x8 steel wheels and 3.75" backspacing. What's the minimum amount of suspension lift I can run with this setup, keeping in mind articulation and hard off-roading are not factors? I would prefer to not use a body lift.
Whatever lift kit I buy, I will need one that includes control arms. The lift on the Jeep now has some wear in the poly control arm bushings and the shocks appear old as well, so i intend to replace everything at the same time. One option I am looking into is: https://www.4wheelparts.com/p/genui...-set-of-4-tjs-tjstg238-4/_/R-ADDK1-TJSTG238-4
I am aware there are better products on the market, but given the intended use, I doubt I would ever see the benefit of a lift that is double or triple the cost. Do better reasonable options exist? I don't mind paying a little extra for higher quality if I can actually see and use the benefits. For my needs, I think all I need is enough lift to fit 33" tires and nothing more. But I have no previous experience with these vehicles so I would like some input based on real experience.
