I bought my 2005 Rubicon from the original, only owner in 2020. His son is a certified mechanic and they also had a nicely built YJ, which was encouraging. Generally I have found he took great care of this Jeep, including a valiant effort to save it from rust due to road salt; overall it’s in good shape for up here.
He installed a Rubicon Express 3.5” lift (springs, shocks and sway bar end links. Drop pitman arm too I believe). Now the springs are rusted out and the ride is “darty”/engaging and I want to do it right. So I am replacing all that with:
Currie 4” springs
Currie fully adjustable control arms (all 8)
Currie bump stops.
JKS quick disconnect front end links and regular JKS rears.
Ranco RS5000x shocks (RS55256/RS55255)
The front trac bar looks factory but he drilled extra holes to move the axle mount toward the drivers side. Not a huge fan but leaving that for now. Stock front steering with Rancho stabilizer.
The rear trac bar has a relo bracket.
Rear shocks have extension perches.
So I’m hoping to be able to leave all that as-is for now.
The goal of this thread is to document the project, provide a resource for others replacing PO parts with new, and hopefully help solve some of the mysteries encountered. I’m sure I’ll be asking for help as I go too so thanks in advance!
Before:
Currie 4” springs
Currie bump stops.
Before:
