Heading to Moab for the first time in June
06 Wheeler
Ohio
I'm heading to Moab for the first time in June. I'm interested in running Steel Bender, but do not think my 2 door with 33's is up for the obstacle nicknamed "The Fall." Does anyone know if the fall on Steel Bender can avoided? Attached is a trail map from "Moab, UT Backroads & 4-Wheel Drive Trails." The fall is labeled as the extreme ledge in the bottom right hand corner of the map. I am curious if the trail can driven in the following order: 1-2, 4-7, 3, and then when you reach 3 is it possible to run 3-1 in reverse to avoid the ledge?
The obstacle appears to be on the trail that goes to trail #46 and not at waypoint 03. So it looks like you get to avoid it regardless of the rote you take. The maps are very accurate.
That’s the one 😬
That’s how I read the map as well. I just thought the obstacle was serious enough to see if anyone had first hand experience running 3-1 in reverse direction to exit the trail and avoid it. Tricky part is in the book trail 46 is also steel bender
