Thimboslice, I tried for my 03, as torx points were rusted/stripped. Plus rust on threads resisted turning. I bought used light set and you can probably get new screws, but design is terribly weak. They are held into plastic frame by very slight shoulders that likely normally break when you push out old screw. Appears like a factory only install when plastic is fresh and flexible. I think only frame unit is available from stealer, like $100 or so each. Someone here cut slots for a regular straight blade, as a work around, but there's very little material to the screws, that might be a good option. As someone said, make sure threads are clean of rust as possible with limited resistance threading into plastic frameAnyone have to replace the alignment screws? If so, where did you get them?
Try this number: 55055032AEI cant find them on there. Just like everything I try to do a search for on quadratec. lol
