Is there a write up on how to fix the heat soak problem with spark plugs? 2006 4.0, auto, 126k. I'm getting a "want to stall symptom" when I stop at red lights when its hot outside and in stop and go traffic. Thanks
Yes I‘ll do that. But is ist also good to install the insulation sleeve between Headers and manifold? I think so. But there all the same who fit between 1997 and 2006? I don‘t unterstand the recall only from 2002 till 2006. What is different?That looks like rub/abrasion damage- separate the wires see if there is any damage repair and then bundle back up.
Looking for this insulation. Will it fit 99 TJ too? When yes, I‘ll do that work too. Insulation of the Injectors and Rail is ready.
Yes, that‘s Right. I could have one. My question was if it fit also 99 TJ. Cause the recall with this insulation sleeve was 2002-2006 TJ.You can find it on Ebay. I got one from there a few years ago.
I've installed this insulation kit and I still get the heat soak issue. GRRR!!!
