I just sorted out the heater in my TJ, I am fairly certain it was a failing motor pulling too much current. It cooked literally everything though... The resistor still needs to be replaced so all the speeds work, the main switch bit the dust, the relay was melted, and the harness was fried in each location. I think the speed selector switch survived according to the multimeter . It looks like that has been replaced once as well as the plug at least, so maybe its fine. The resistor is bad though, only have low low, medium low, and hurricane force.
Regardless, looking over the wiring diagram it seems like everything that got toasted near the switches was on the ground side of the motor, and the relay is on the hot side. Logically it seems that it was a bad motor causing the magic blue smoke to leak out. Are there any other failure modes that can cause this issue that I'm not aware of?
