Thoughts? New to Jeeps and new to car repair. If I can diagnose it I’m confident I can repair it. I think it might be the cap or maybe the tube’s clamps? I’m hoping someone will be like: “Oh I had this totally happen. It’s ____.”
Check the radiator for cracks?View attachment 118484
I would try to wipe it off really good and then start the engine and watch it to see if you can then tell where it is coming from. It looks to me like maybe the cap is leaking.
It happened while doing errands so my plan is to check it with the suggestions I get from here
What does your temperature get to when its warmed up?
I'd take the cap off, look at it and the hole for debris, and put it back on. Make sure it's on all the way and locked tight.
Just go rent the tool, it replaces the radiator cap (with it cold) and you can pump up the pressure and look for the leak without getting burned (literally). Right tool for the right job...
This really is the right way to find a coolant leak.
Why yes it will, it has an adapter to fit the cap on and pressure test it.Will the tool find a leaking radiator cap?
Edit: I really don't know I've never used the tool.
https://www.amazon.com/dp/B004FDL1TW/?tag=wranglerorg-20Hahaha, actually no. That's literally the ONLY part that it won't find. The kit has a bunch of radiator caps with one-way nipples in the middle that you connect a hand pump to. You just install the cap that fits your radiator, pump the system up to pressure, and start looking around.
Depends on the kit. The one I have does not, but I'm cheap.
