Help me build my lift
Josh H.
SE Ohio
So it's time now for me to finally get rid of the spacer lift currently on my Jeep and put in a "true" lift. I want to stick with 2.5 inch total suspension lift with a 1.25" body lift as well. Not 100% so far on which springs yet. I was originally thinking OME 2" HD springs but I can't seem to find a part number for just the springs. Any suggestions on which springs I should go with?
I'm going to go with Rancho 5000X shocks and a Savvy 1.25 BL and 1 inch MML. What else will I need/ Should I replace on it suspension wise? Being 20 years old I figure its time.
Once I get all the parts sorted I'll put together a list with part numbers and post it back in this thread.
Any and all suggestions are welcome. Links and /or part numbers are greatly appreciated!
Link to OME springs https://dpgoffroad.com/product/old-man-emu-3/
You will need to decide if you want the light or heavy front springs. If you have an aftermarket bumper and winch or plan to add one later you will want the heavy front springs.
Reactions: Josh H.
Appreciate that! I think I'm going with the HD just in case. I plan on an aluminum bumper but also a winch. I also usually carry a decent amount of cargo with me.
Reactions: Thumper4fun
You'll want an adjustable front track bar and at least a rear track bar bracket. Also will want extended front sway bar links / disconnects. Sounds like a solid build. The OME spring part numbers can be found on their website, several retailers sell them.
Reactions: Josh H.
Probably going to go with Currie Front track bar. Already have an AntiRock so thats taken care of. Appreciate it!
Reactions: IPerkWVU
OME springs,
2933 front
2942 rear
Rancho shocks,
RS55239 front
RS55241 rear
Check on that Currie tb. Could be clearance issues with a lower lift.
If you are running 33's then you'll need to add some bump stop extension front/rear.
OME springs,
2933 front
2942 rear
Rancho shocks,
RS55239 front
RS55241 rear
Thanks for confirming I had the right springs/shocks. I’ve got a spreadsheet started with part numbers and links so I can hopefully keep everything organized and not forget anything.
The Currie TB says you need a minimum of 2” lift so I should be good.
33’s and a regear is the plan and I will follow the excellent threads here to set my stops correctly.
Thanks!
Reactions: bobthetj03
Figured I'd go ahead and post up my spreadsheet since I'm getting ready to start the buying process. Any more recommendations are welcome!
Looks like a well thought out list. I’d love to see pics when it’s done!
Food for thought...
Adjustable rear track bar or bracket
ZJ or crown hd tie rod
Monroe steering stabilizer save yourself $30 which pays for the rear bracket. Paint it white if you want it to match.
From what I’ve read, you may need a spacer up front to even out the lift.
Thanks for making a list with links.
Reactions: Josh H.
Food for thought...
No problem! Definitely gonna keep this thread updated with pics. I haven't decided on which direction I'm going to go with the rear track bar yet. I will update the spreadsheet when I do. Thanks for the feedback!
