I'm dealing with a leak on my passenger side door. Any time it rains, I find a small puddle of water under the front passenger-side floorboard. I also find a small amount of water under the rear passenger floorboard.
I finally had a chance to get inside my jeep and have someone spray the water hose on top of the door, and the leak is coming from the front hinge area of the door. And it's more than just a drip. It's more of a constant light trickle of water coming in.
I opened the door to check it out, and it looks like the problem may have to do with the door seal. It looks like it's pinched in one area, and that appears to be the area where the water is coming in. Based on the pics I'm attaching, should does it look like that door seal is the issue? And if so, does anyone have suggestions for fixing it? Or should I just replace the door seal? I can't figure out why it would pinch in just that one area. And even if I pull the seal back up, once I close and open the door, it's pinched again.
I also included a couple of pics that show some electrical top on the very front corner of the hardtop. I'm not sure why it's there. I removed the tape, and it doesn't look like it was serving any purpose.
And as for the leak in the back seat, I didn't see any water coming in from the back side of the door during the test. So I'm not sure how that area is getting wet. Although it doesn't get even remotely as wet as the front floorboard.
