There is nothing wrong with running a TrueTrac in the rear unless you are trying to turn your TJ into a billy goat going up the side of a mountain. For applications outside of rock crawling, it adds a ton of capability at a fairly low cost. I have slogged through stuff without even having to engage 4wd that would have stuck open diffs.
Is the TT as capable as as full locker? No it isn’t. But it works flawlessly on the road, in most light to moderate wheeling conditions, and even in tight turns without any user interaction. Is it capable enough for the OPs intended use? Most likely and definitely worth a try vs throwing a ton of money at upgrades he may never need.
