Thank you for all the replies.
I dont have a scanner but I use the 3 turns trick to get the code on my odo.
I pulled the coil pack again and checked the primary this time. I was not completely sure which contact in the 4 pin was positive but any combination that I tried the ohms were very low. Around .005k going for the coil pack and if not that then going to check harness. Blue streak ordered.
