I have a 2002 Jeep Wrangler that has a Pro Comp 2 inch lift with 32 in tires. Ever since the lift and tires there has been a vibration, mainly from my seat and center console, that starts at 50mph and gets worse and worse as I go faster to the point where the vibrations shake the mirrors where I can't see out of them. I figured it was the tires being out of balance, so I got then balance three times by two different shops, one being a dealer. However, the same vibrations remained so i had the dealership look at it agin for other causes. They said it is not uncommon for vibrations like this in an old jeep and also that the driveshaft is at an extreme angle. Could the drive shaft be the culprit, and how should I fix it? A slip yolk eliminator?
