While waiting for the rear driveshaft to come in I decided to clean the garage and tackle some various smaller projects before starting on the front (Tom Wood said I'd receive the DS a week after I ordered). I have been super excited to install my supercharger kit from BoostedTech and have the luxurious break of follow instructions again. These kits are awesome because they use the ultra reliable Eaton M90 and provide all of the install brackets to allow the hood to fully close without cutting a hole in the hood.
First I washed the engine bay to make things nicer for me to work on and prevent any dust from getting into the engine. I removed the hoodliner which I plan to wash separately and reinstall towards the end of my build.
For use with the supercharger I needed to change my spark plugs out to some that are 1 heat range colder. BoostedTech suggests Autolite XP5224 Iridium. They came out of the box gapped from 0.000-0.050" so I spent the extra effort to make sure I had them all gapped at 0.029-0.031".
I setup my laptop on a table next to my Jeep with the PDF instructions from BoostedTech pulled up and got to work taking the engine intake apart:
As I progressed through the install there were some steps that seemed downright missing vital details and calling BoostedTech didn't provide many answers about installing their kit. Between my general knowledge, some online searching and the FSM I was able to get things figured out. At one point the instructions simply mention to connect up the vacuum hoses and don't mention what connects up to what. Thankfully BoostedTech wonderfully labeled each bag of bolts individually and each of the hoses to where they go. The overall physical quality and packaging of the kit is top notch.
The AC lines had to be bent quite a bit to clear the steering pump and supercharger. I found that unbolting the clamp holding them in the middle of the engine and using a soft-face hammer helped get them where I wanted.
The included belt wouldn't install for the life of me unless I placed idler pulleys too close and over tensioned the belt. BoostedTech told me this would all be fine but I felt uncomfortable with that so I purchased a larger belt to fit. Around this point I realized that our build philosophies are very different which surprised me due to the well thought out nature of their kit. The luxurious break of follow instructions I dreamed of remained a dream.
(The air filter pictured was only used for testing the engine after installing, I'll be going with a better solution towards the end of my build.)
My 2004 year requires a the ECU to be programmed to go into open loop when the MAP sensor sees boost. If the ECU stays in closed loop it can run the engine too lean. When I purchased the kit there was an option for a replacement ECU that is already programmed for my Jeep which I opted for. This is where my major issues with BoostedTech started, my Jeep has SKIM enabled and the ECU they provided has a SKIM delete enabled of some sort. This allows the engine to run but for the SKIM key functionality to not work and for a "No Key" light to stay lit on the dash. I called BoostedTech on this issue and they told me it was my issue and suggested putting tape over the dash light and they wanted $140 to fix it. Now if it was my issue I get it, but I ordered a kit and provided all of the details about my Jeep they asked for. Additionally, as we talked further about how they'd resolve this issue it became clear that they had no clue how SKIM works. After I explained how I didn't understand how it was my responsibility to pay for their oversight (which they agreed with me that they should have asked me more questions during the checkout process — and will be adding those questions to better help future customers) they became defensive and unwilling to waver from the ECU problem being my issue.
Thankfully I have a few contacts that I called up including 1 of the only 2 known people in America (or maybe the world) who can fully program the Jeep ECUs. I sent my ECU to him to have SKIM re-enabled so it could be programmed to my SKIM module again. While he has my ECU he'll also be doing a few other small changes that I'll cover later in my build. The other person I contacted is the only person I know of who is able to pair my SKIM module with my ECU without the dealer. Once we're all done playing hot potato with my ECU I will hopefully have a properly functioning SKIM security system again. In the meantime if I need to move my Jeep I still have the factory ECU in my possession. Thankfully I didn't install it as a weekend project!
Overall I would buy another supercharger from BoostedTech, but with the understanding that there's not much support after purchasing and that I'd need to spend an extra chunk of cash to actually get it working properly.
