I think I found the perfect belt length of 86.6". Continental 4060686. Application is an early 1990s Volvo 850.
Tox - I've enjoyed reading your chassis build and now this thread. Super informative.
If you haven't already found them, GM make bolt on plastic dust covers for the bellhousing/engine interface openings.
ACDelco 24261712 and 24261713:
View attachment 232295View attachment 232296
Also, be careful using Dexcool. It is sensitive to contamination and air in the system (it basically turns to brown sludge). It works well when everything is good, but can have serious consequences if it's not... clogged heater core, clogged radiator, block full of gunk, etc.
Good luck.
Very interested in how your RPM Extreme harness works out. I'm doing this LS3+6L80 conversion with this same harness kit but you are much further into the swap.
Ok thank you. The ECM that came with my RPM harness is an older vintage than that of the ECU that came with my new LS3 so i can't use the GM harness. I need emissions to work so crossing my fingers the RPM supplied ECM still has these items functioning. I was working with Adam from RPM.
From what I can tell that looks solid, and gives plenty of clearance for the transmission skid. It hugs nice and tight.Trying out a different transmission line. I think this might be the best so far (cheapest too). GM #92236244.
