Hood compatibility
mkc1962
Alabama
Part of my project 2000 TJ will be to replace the hood and driver fender that was heavily damaged prior to me aquiring. From all I can tell a 97-2006 all had the same hoods. Can a later model Wrangler hood say in the 2019 vintage be made to work on a 2000TJ? or are they that much different.
I have a lead on one that is darn near free with a small dent. Picture wise it looks near identical except the area where the washer nozzles mount.
Thanks for any input.
No. You need a ‘97-06 TJ hood
Reactions: AndyG
The differences I'm aware of are the early 97s had a different latch and 97-98 had two washer nozzles rather than one.
I have a '97 hood installed on my '05. This is correct.
I put a Y in the washer line to accommodate the two nozzles in the '97 hood. The latch is a bit trickier, because in 97' the latch is in the grille, whereas in later years it's mounted to the hood. There is a spot on the '97 hood that you can install the later-model latch and make it work. It requires drilling a hole and optionally (ideally) popping a rectangular locator notch for the latch into the inner layer of sheet metal.
I got a '97 hood cheap, and couldn't find a later-model hood to fit... so I made it work. The other option was to install the '97 grille I have... but that would have been way more work along with what's been called "mental gymnastics." :rolleyes:
Complete Auto Recyclers east of Huntsville may have a stock take off.
