Just driving around and the indicator line is slightly past the 210. Don’t know if it’s overheating or if this is something that’s normal. Mind you, it is 95 out right now but I don’t know if that plays into this.
I used my buddy’s OBD II scanner but his doesn’t read engine temps. It’s a super cheap one. I have to get an OBD II reader anyways. Perfect timing I guess!It is not accurate enough to tell you anything if you suspect there is something wrong in the cooling system. My gauge ran just where your gauge sits while the engine was running 230 - 240 due to a failed thermostat. I would recommend checking with an OBD II reader to see what the actual temperature is. If you are running with the gauge above 210 when just driving around town it can't hurt to check. On the highway, the gauge running above 210 is more normal.
The gauge is accurate enough to tell you that the engine is overheating extensively but not necessarily accurate enough to tell you that something is wrong within the cooling system.
Accurate enough and that's right where the engine was designed to run most efficiently at. Don't give it another thought or pay too much attention to the hand wringers..
