I fixed my aftermarket remote starter!
How?
I did it by changing my rear stop light bulbs from LED to incandescent. I’m an engineering genius.
Ugh.
I never used the remote starter all summer, but with winter coming, I thought I’d check it.
(it’s a necessity here on certain days - thanks to my old boss for forcing us to park a 5 min walk in a field with no block heater power. Unless you live in a norther area, you may not understand the issue when it drops below -30’C or F and not be able to plug it in).
It’s also “nice” to have on other colder days, just to have it warmed up prior to getting to it. But I digress.
The remote starter failed with the error code “the foot brake pedal was ON”.
Which it wasn’t. But what would make it give think that?
I remembered that the canbus system on TJ’s went all haywire if you put LED in the turn signals.
A few years back, I had installed the flasher to “fix” the LED turn signal issue, and have been happy with it.
This summer, I replaced almost everything with LEDs, including the brake lights (which mimiced the dual filament thingie).
I enjoyed the brighter led brake lights. I also liked the idea that the electrical load overall on the system was lower. (I had replaced 3 burnt out headlight switches before before installing relays…and then LED headlights).
The “electrical cost savings” is quite minimal with brake lights I imagine, but I was buying other bulbs, so I figured, “why not?”.
The “not” part to LED brake lights is that it apparently makes my remote starter fail
So now I have 2-4 options:
1. Keep the old incandescent brake bulbs in
2. Figure out some load resister to mimic incandescent bulbs in the brake lights? Would this be the same size resister as the ones I read about for turn signals?
3. Wire in another brake light socket with an incandescent bulb in it? Which is kinda pointless IMO.
4. figure out some way to bypass/fool the remote starter from checking the "brake pedal" to not use electrical load of bulbs
So unless someone knows an easy/cheap way to “fix” the remote starter from falsely thinking the brake pedal is on…because I have LED brake lights, I’m probably going to have to keep using the incandescent bulbs for now. It’s not a major issue, just a bit psychologically annoying, because I bought LED bulbs that work perfectly…except for the remote.
If anything, I hope this helps anyone else that suddenly finds they are experiencing remote starter (or other device) issues that are related to LED brake lights.
How?
Ugh.
