I have mostly settled on my build road map
I can affirm the GY MTR wear unevenly. They also don't play well in the rain. Mine didn't at least. I prefer the Cooper's so far.
https://www.4wheelparts.com/p/goodyear-lt265-75r16-tire-duratrac-312018027/_/R-DVFB-312018027
This begs the question:
Which is more important
A) 31.5” vs 34” -or-
B) E load rating vs C load rating?
Well, size tire and load are doing two different things. C load are right for the weight of your TJ. The E load will be way to stiff and make for a rough ride.
A smaller tire will give more onroad performance due to them being closer to ideal gearing. A larger tire will give better offroad performance due to ease of rolling over objects. I don't know what your'e trying to accomplish overall, but if you get a 15" wheel you can find lots of 31", 32" and 33" tires with a load range C, and a few 35's. Any of those would be good combinations.
Reactions: Neil Sears
I’m trying to find the best tire for my specific needs (driveability on road, often hundreds of miles to my destination plus good snow grip as I have a cabin in the local mountains) that will fit TJ Moab’s.
At this point I’m have no real desire to switch to a 15” wheel.
You could run 265/75r16 it's 31.7 tall, the general grabber x3 and duratracs both run in load c in that size and keep the stock moabs. With that size you could skip the BL and MML. I was going to do this but ultimately went with 285/75r16 MT MTZs in load E as I wanted the larger size for off roading. It rides ok down the road but I wish I had the sidewall flex of a load c tire. I run about 26 psi.
Thanks. The 26 psi with the 33” Duratracs seems to be the way a lot of the Toyota guys go.
I even have this as the path on my build list above.
Seems to me Goodyear is missing a big market here :(
I was going to make the “why is everything always about you” joke but I don’t know you well enough yet.
So with that in mind: Why, a bummer for you?
Haha! No worries.
Because I run 35s and I absolutely love the Duratrac from the years I used to have them in 33”. However, since they don’t make a true 35” in a C load range, I am stuck with other tires. That load range makes a huge difference in ride quality.
Haha! No worries.
Road or Off Road ride quality?
