Today I did some general maintenance on my Jeep and it took me some minutes and some hammer hits to realise that I had not removed the retainer plate bolts while I was trying to remove the rear axle shaft. It is a Dana 44 on a 03 Rubi. After I put everything back together I noticed that there is a bit of in and out play on the right side, the one where tried to take out the axle shaft before removing the retaining bolts. What is thr worst case scenario of could have happened? As long as I didn't damage anything in the diff I am ok. The axle shafts are are stock.
Cheers,
Dan
Cheers,
Dan
