So a year later into the LJ project I've made some progress on what I considered my "build sheet". The few times it's been out on dirt it has done extremely well - notably the 3 day Red Clay Rally this past fall.
At the end of the day I'd wager the Rally will be the hardest this is pushed on an annual basis. Aside from state forest OHV trails in the southeast and occasional trip to Windrock its mostly a fart around fun vehicle.
Any decent riding is a minimum 1.5 hours from my house which would be interstate travel.
So where is the impasse? Do I invest into all that is needed for 35's or keep rocking a 33? Ideally I'd like a 285/75/17 (34") but don't really think 17's would look well on a LJ - maybe they would.
Current setup:
04 LJ
42rle
Dana 30/44
5.13's
ARB's
Currie steering
Savvy 4"
SYE/DS
33x10.5's
Current set plans include:
- cage for the inside, local shop is building this summer
- RCV axles for the Dana 30
- big brake kit 15" if I stick with 15's and 16" super kit if I go to a larger wheel.
So this is where I get stuck - do I add a Savvy BL, MML, and savvy tcase cable and go to 35's.......or do I enjoy my sweet peppy power with 33's (or 34's) and keep on having fun with where it's at.
Thoughts:
- not a fan of body lifts, I know they are fine but just don't like em - call be stubborn
- 35's will kill what power I got back from going to the 5.13's.
- Don't really want to do a proper hi-line fender conversion as I love the factory bush truck look I've set out to build.
- 35's on 5.13's with 42rle probably sucks on the interstate - so drives to and from trails would suck.
Where I diffed out following the big rigs at the Rally also diffed out a few TJ's on 35's. We all had to pull line in the same spots, so trying to justify from a performance standpoint.
The other option would be looking at 16" or 17" wheel options to allow for the 16" big brake kit, it seems to be the way to go and swapping to a 255/85/16 or a 285/75/17 MT which keeps me in the 33.5-34" range.
I bought this wanting to build a very capable trail truck to run on 33-34's, I knew it would be much easier to go with a JK if 35-37's was the goal.
So do I go to 35's and all that's needed or re-enforce components (brakes / axles) and keep on rocking the 33-34" range?
I'm 50/50 depending on the day and want to set things in motion here this week or next
Current setup:
04 LJ
42rle
Dana 30/44
5.13's
ARB's
Currie steering
Savvy 4"
SYE/DS
33x10.5's
Thoughts:
