Inexpensive Black Steelies
17" Black Rock series 942, type D with 265/70 Duratracs are working well for me
  • Love
Reactions: John Cooper
4WP had the cheapest black steelies i could find. like 50ea IIRC.
Both Jeeps i purchased came with pro comp d style steelies. I like the look.
I didn’t have any issues off-roading with them in the local rocks, but I went to aluminum when doing the 5x5.5 Hubs mostly because I wanted less rotating mass.
And if I scrape a wheel I’ll just paint it black and move on with life.
Procomp steelies are cheap ass chinese junk. I spent a ton of time trying t ofind a wobble at 62 MPH. Balance, new tires, balance, balance again. No joy.
Screw it. I bought american made forged aluminum wheels. Right out of the tire shop 70 mph straight down the road.
I sold those POS procomps to a guy with a YJ. 10 bucks apiece.
They suck big black ones.
Depending on what type of wheeling you do, steel may not be the best option. I ran steel for a few years and got to the point where I was bending the rim lips on every outing. I recently swapped them out for a cheap set of aluminum rims and will see how they hold up.
Now running what I believe to be an Ion Alloy aluminum wheel of some kind.
Depending on what type of wheeling you do, steel may not be the best option. I ran steel for a few years and got to the point where I was bending the rim lips on every outing. I recently swapped them out for a cheap set of aluminum rims and will see how they hold up. View attachment 326752View attachment 326754
A forum peep local to me, had gotten tyred of rebalancing his steel rims after every outing.
Reactions: Lax22
So true. I have some rebar rings I plan to weld onto the steel rims I just dismounted. If the aluminum rims hold up, then I’ll just sell them and keep running them until in need new tires.
Reactions: RINC
If you wheel it at all, I'd go toward a cheap alloy wheel. Steelies bend up too easily if you play in rocks much.
If you don't, I can't recommend any steelies.
Steelies bend but dont break. Then they can be bashed back to hold a bead.
