To play a game common to this forum, what problem are you trying to solve? Do you know what CLD tiles are used for? Ok, enough of that Lol.
If your jeep is noisy, which they are, I really don't know how much more you'll gain beyond what the factory produced. Although HT and full doors are by far the most quiet configuration, its not that quiet. If you wish to embark upon this journey, allow me an opportunity to tell ya about the products involved.
You'll need -
CLD tiles
Closed cell foam
MLV
Hydrophobic melamine foam
Each of the above is a piece of the puzzle. Each by itself will do what its intended, but it takes all of the pieces to complete the puzzle.
Quick rundown of the above products.
CLD tiles or Constrained Layer Damper is used for reducing structural vibrations or panel resonance. Large metal panel transmit noise like a speaker, adding CLD tiles reduces these vibrations.
Here's the thing, to properly work, only 25-30% of the panel needs to be covered. The audio industry perpetuated the myth that the whole car needs to be covered. Examples of ppl blindly following misconceptions of others can also easily be found in the jeep world.
Closed Cell Foam is used to decouple one object from another. An example would be a plastic door panel and a door or MLV from a panel.
MLV or Mass Loaded Vinyl is used to block noise. Its very rigid and can only make simple bends. Its trimmed to mirror a panel and would be used anywhere except overhead.
Hydrophobic Melamine Foam or Acoustic Foam is used to block high pitch frequencies and/or noise that's already inside the cabin such as echoes.
Properly adding CLD tiles to a jeep tub will make a difference, I'm just not sure that difference will be worth pulling the interior. Covering your whole tub in CLD tiles will also make a difference, I'm just not sure that difference will be worth pulling the interior, the money spent or the time involved.
But, to each their own. If someone wants to run a long arm, I'm not gonna stop em! Hehehehehee
