Ok, here's an update on where I'm at with this project.
I got the track bar bolt replaced so that I could continue cycling the suspension, as I still needed to take measurements at full stuff.
It didn't take me long to find my first interference which is the zerk fitting on the track bar making contact with the lower spring perch.
I'm assuming this is a track bar adjustment issue? Should I put the springs back in and do the track bar adjustment now and get it centered before continuing to cycle the axle?
At this interference point, I've still got quite a ways to go before the driver side tire will be into the fender.
