I'm going to go ahead and call this SOLVED via new spark plugs (I also added new O2 sensors and reverted back to my previous Crank & Cam Position Sensors).
Great work, has to be the best feeling.
It was stressful with no codes to fall back toGreat work, has to be the best feeling.
Are both CAM and CPS mopar? I would toss your old CPS in again and see what happens. Also check the timing to make sure you were at TDC on the compression side, its possible your off just a hair..
Put an infra red thermometer before and after the cats . You want it about 100 degrees cooler after the cats . If not , they need checked . A hand on the exhaust can tell, you sometimes.
I realize by the posts you may have a ground or similar issue as well.
Man I hate that you're having to go through that.I will call this progress, but not tons. After reorienting the OPDA at TDC closer to where the old one was - I am now only getting U0155 codes. Now to figure out how to test the cluster. The FSM has some ideas, but since the issue is intermittent it's hard to say that those tests would show me much - though I will probably still step through them to see.
I'm exactly the same way.. I have a terrible history of falling in love with my vehicle's even long after they become unfaithful.You and me both @AndyG - if I wasn't so obsessed with it I'd be thinking about trading it in (and honestly have thought about it a few times). There's just nothing else I'd want.
