If you need to replace the Dana 30 for mechanical reasons, and you don't plan to run over 35" tires, then a HP Dana 30 is a good alternative - especially if you already have 4340 shafts in your Dana 30, since they will slide right into the HP Dana 30. The HP Dana 30 is reported to be 30% stronger (going forward) than the Dana 30 since the pinion teeth engage the "drive' side of the ring gear teeth.
Unless you need to go to 5:38 gears, the ramp up in price between a HP Dana 30 and a Dana 44 is not really worth it since everything except the pumpkin is the same as a Dana 30. Going to a Currie 44 is really not a comparison unless cost is of no concern. And if you plan to go larger than 35s, you might as well plan on replacing your rear with a Dana 60 while you're at it.
