What's the standard practice for tailgate armor on a late model? Do I need to cut a hole and reinstall the vent, or just leave it off? If it helps, I'll be running the stock tire carrier and MORyde hinges.
I still don't understand it's importance on a vehicle with a top that is so lacking in air seal anyway... IF on there for the option of a hard top, just add the vents to the hard top... oh, wait...
Don't bother adding the vent if you are just running the soft top or no top.What's the standard practice for tailgate armor on a late model? Do I need to cut a hole and reinstall the vent, or just leave it off? If it helps, I'll be running the stock tire carrier and MORyde hinges.
Just open a window a little when closing the door so your ears won't pop. It would mean no flow-through air ventilation though. And your hard top is a newer model without the vents on the rear sides right?I run the hard top from December to April and soft top the rest of the time.
... but the pressure increase is not even close to making my ears pop.
It's a non-issue IMO. I've got an LJ and tailgate armor with the vent removed. When I have the hardtop on the difference is hardly noticable. It may take slightly more force to shut a door with the windows up but the pressure increase is not even close to making my ears pop.
I bet your jeep makes fart noise out the tailgate when you close the doors, you just don't hear it. Like an old man walking around the store, just crop dusting innocent folks.
It isn't a fart noise. This whole time it's really been his ears popping.
edit- popping, not pooping
No lj has factory hard top vents though because Chrysler
I'm starting with a 1 3/16 " "fart valve". It can always enlarged later, if needed.
