Denny's Driveshaft.
Be sure your slip joint is not worn. If so, you need a new driveshaft.
They have a website?
Denny's Driveshaft.
Thank you so muchI’m pretty sure I found what I need…. Actually pretty reasonable on the price too… I’m glad yall recommended the site to me…
And I just noticed the kit is currently not available…..
Thanks yall for the input… the strap bolts are all rusted…. I’m gonna have to order the parts from the internet… any body have the part numbers I’m gonna need? I’m gonna go ahead and just rebuild the whole thing while I got it apart… I think that’d be best…
I got some penetrating stuff to go ahead and start spraying stuff ahead of time and spray it every day till my parts come in….
I know it’s not gonna be easy lol I can handle it… may take me longer than more experienced people but I’ll get it lol
Thanks again yall!
When you responded that you have some penetrating stuff; what kind of penetrating stuff are you using ?
Some (Liquid Wrench, PB Blaster, Mouse Milk) are better than others, but when all else fails... try mixing one part ATF to one part Acetone.
Years ago in the USN one of the older sailers turned me on to this mixture.
The ATF/Acetone mixture will creep into areas to free up rusted parts better than anything else I have used other than applying heat to the area.
If you have a lot of rust on those bolt threads; that Walmart special may not be enough to penetrate the rust.
Acetone can usually be purchased in the paint department of HomeDepot, Lowe’s, most hardware stores and even Walmart.
That is the greaseable kit, pretty sure your factory set is sealed. My 06 was.
