I had an overheating issue and determined the fan clutch was bad so I replaced it. Problem is definitely better however I still think I may have an issue. Any advice is appreciated.
- Purchased a bluetooth OBD reader so I can get real time temps through Torque app.
- All data below is from a 20 minute drive today.
- Temperature normally runs at 211 deg without the AC on. Outside air temp is 86 deg.
- With AC running it goes up to 217.4 and seems to stabilize there until I come to a stop and idle.
- Went up to 221 while idling through the Bojangles drive through with AC on.
- Went back down to 219 when I got back on the road - AC still on.
- Went back up to 221 at stop sign then back down to 219 on the road.
- After I parked, I could hear the coolant boiling in the radiator, but it wasn't overflowing the overflow reservoir like it was doing previously.
