Your thrust angle is a bit high. Like Rex mentioned, check to make sure your axles are square to each other. I pulled my alignment sheet to compare, and my thrust angle is 0.09*. Also, why is your toe off on the left compared to the right? Lastly, your caster is about where it should be, but 6* would be better is you have adjustable arms.
