Yes
Yes there is a small hole in the front corner for now, it's hidden in the picture from those angles, I'm going to make it bigger and install an A/C drain nipple as I found the small hole easily gets plugged and is difficult to clear out, A/C drain should fix the problem.
Did you put a drain hole in your air box?
