We all know that RockJock/Currie is the best front trackbar...but for those of you running the JKS, have you noticed it bending or collapsing at all? Reason I ask is my steering wheel seems to rotate off center after a good wheeling trip. Has happened a couple times now. Last time, the culprit was the Rod Ends on the axle side. The little kink in there from the factory became a much bigger kink. I straightened it, and after my Kentucky trip, the steering wheel is off center again.
FWIW, I'm running 4" of spring lift, Currectlync steering, JKS trackbar, and 35's. No Hydroassist. I have checked my frame mount and it does not appear to have any cracked welds. My steering box is tight. Anyone else experience anything like this?
