KC H3 Halogen Replacement
Unlimited4x4
Just picked up a set of used daylighters, spot light. Looking for a bright white (above 4000k) color halogen bulb. Anyone have any experience with a certain bulb? Eventually they will get converted with the gravity inserts, but until then…need some new bulbs. BTW, already converted one set to the driving pattern Gravity led, well worth it.
Thanks
100 watt H3s will give you significantly more light. Unless you use different lights, as far as I know, there isn't an H3 LED replacement that works in a housing made for H3s.
At the moment I’m looking for a H3 bright white halogen bulb. I guess my post wasn’t clear. The only way I will go led is with the KC inserts.
