Hey gang, 65th Anniversary Ed. with a set of 3 bumper-mounted halogen KC HiLites the PO added. I've had the Jeep a little over a year and they haven't ever worked.
It's bothered me for long enough now I'm trying to figure it out. So, here's what I've done so far:
I can add pictures if that's helpful but based on the YT videos I've watched, it seems to be a pretty standard setup. Ideas? Thanks for your help.
- Checked the bulbs--all filaments appear intact
- Checked bay and interior fuses--all good
- Tried all lighting combinations--lights off, markers only, low beams, low beams + factory fogs, high beams
- Checked the connector between the light assembly and the pigtail into the engine bay--looks good, no corrosion
- Checked the wiring at the bay fuse box
- Grounded to bay (black)
- Yellow/White running into relay, Red/White running out of relay
- Red also has in-line 15A fuse and is wired to battery and fuse box terminal--15A in-line fuse was blown but replaced and still nothing
- Followed wiring through firewall
- Wired cleanly into rocker switch in factory auxiliary gang near cigarette lighters
- Pulled out center stack dash bezel to check rocker switch terminals--still clean and shiny, clip firmly attached
- Went through with a voltmeter--everything seems to be putting out the right power
