Hello, 2002 TJ Sahara 4.0. Starts good 1st thing in the morning (1st start of the day). After that suffering from hard starts after that. Checked fuel pressure and system pressurizes to 40 + on first key turn and then starts to drop slowly. I crimped off the fuel supply line going into the fuel rail and the pressure still drops very slowly (approx 2psi per minute). If I remove the clamp pressure does not appear to drop any faster. I noticed when I clamp the line that pressure in the rail rises a few psi and then drops off at the slow rate which makes me feel like I had the fuel supply fully clamped off removing the check valve and pump assembly out of the equation. This leads me to believe I have a leaking injector which may be dumping fuel into a cylinder after I turn off the Jeep and causing the hard start due to a rich condition in a cylinder next time I go to start it. Figuring when it sits overnight fuel evaporates in the cylinder and then it starts fine. I have gotten the cylinder 3 misfire a few times but not often maybe 3x in the last year and it clears and vehicle drives fine even with CEL on. I have the thermal wraps for the rail and injectors ready to go on. Not sure if the issue is the vapor lock however and figure if its the injectors I can swap them while I am doing the wraps. Does this sound like a proper diagnosis?
