I got a set and was super excited to install them - then I remembered I swapped my rear tail lights to Quadratec LEDs!
I’m going to try to rig both of these up in a single housing with a third brake light. Anybody have a spare tail light housing?
Is there something like this for JKs?
Not yet, I need to take a closer look at my buddy’s JK and see what could fit.
And a bump for the last set.
Question: If you wanted to use these strong reverse lights for general rear illumination while stopped but you wanted to leave the engine running when you got out and you have a manual transmission how could you do it?
Answer: With the engine still running, put the transfer case in neutral, the shifter in reverse, and the e-brake on for safety. Then you can step out.
That would work.
You could also wire in a switch to power them separately thru the reverse switch circuit.
That would work.
I knew a guy who would turn on his reverse lights at stoplights and then lay rubber forward at the green. Freaked out anyone behind him
