LED Turn Signal Flasher
FarFire70
Lifetime Supporting Member
USA - NE
Working towards replacing both my front turn signals/parking lights to LED due to flat fender upgrade. I've done my research and thoroughly confused on which flasher relay to pick up. I have a 2005.
I'm seeing LM470 or EP27 as options. Research shows both seem to work about 50% on solving the flashers for the 05-06 TJs.
Has there been a consistency on the best option to buy or am I flipping a coin and buying one and hoping its the right one?
Will this laso work for the 97 TJ?
Just googled ep27 led flasher relay sylvania and found non by that brand.
Sometimes being in business i refer to things by their parent company.
This is what I'm referring to.
Novita is under sylvania.
Will it fit a 97... I'll have to check that.
05-06 is ok and what the OP asked about.
The EP27 is a 5 blade relay, 2000 and older TJ’s use a 4 blade relay. The EP26 should work for your 97.
