It's a part of periodic maintenance on our TJ's. Brakes, front and rear. Inspection, cleaning and maintenance / repair.
Common knowledge is that for the fronts the Black Magic upgrades from @mrblaine and crew are THE BEST upgrades going in the TJ world. But what if you're not there yet? What is the recommended pads and shoes for a stock system? What about the fluid, what does everyone use or does it make a difference? Do you rebuild or replace the calipers when they need it? How about the rear brakes, new cylinders or rebuild them? Does anyone paint their drums for corrosion protection and is it worth it?
What does everyone do for brake jobs on relatively stock TJs?
Here's the link to overhauling the front brakes on a TJ here on the forum: http://wranglertjforum.com/threads/how-to-overhaul-the-front-brakes-on-your-wrangler-tj.642/
How to bleed your brakes: http://wranglertjforum.com/threads/how-to-bleed-your-brakes.528/
