LJ rear tool box
Those look super heavy though, how much does it weigh?
It's not too bad. Aluminum is just about the exact same weight as steel for equivalent strength and that is high quality Aluminum and weld steel so a cheap welded aluminum box that weighs less is weaker by the exact ratio of the weight. If the Aluminum box was high quality 6061 it would be great but the fact is it was welded so it ain't. Only downside of the Tuffy box is I have to take it out and clean up the rust and paint it every few years. Tuffy stuff is top tier, if aluminum was better they'd use it. They know the math.
https://www.tuffyproducts.com/product/182/security-drawer-jeep-wrangler-lj
shipping weight is 97lbs which in my opinion and for my usage is actually too bad.
I think it's 92lbs but still obviously too heavy for you. If I was concerned about weight I'd just get an aluminum top and front plate and use the rear gate to access things. You don't need the bottom, side and rear panel of the box so why carry around the extra weight? It wouldn't be too difficult to cut a few sheets and make some angle brackets to join it all together with your skill set.
Reactions: B00mb00m
I got future plans for tailgate / spare holder that I don't want to rely on the tailgate for locking. This gr8top box should suffice until I can create perfection 🤠
Reactions: pagrey
It looks like a pretty nice product, but its $1500+. Weighs in at 80lbs which is surprising given its made from the composite MDO material.
Hard to tell from the picture, Boom, but that doesn't look like much of a drawer slider. Did they give you an estimate on capacity?
300lbs inside 2000lbs on top.
These fit between the wheel wells of a CJ, YJ and TJ/LJ. Maybe not what you are looking for, but an option.
https://www.amazon.com/dp/B000I1BU6E/?tag=wranglerorg-20
Look at ATV boxes also, like these:
https://www.amazon.com/dp/B018F547UK/?tag=wranglerorg-20
https://www.amazon.com/dp/B08MZQJVFX/?tag=wranglerorg-20
Out of all the examples listed these appear to be the most sane. Pricewise. Will the tailgate cover the lock on the second one? Looks like an added bonus.
But im looking up the tuffy now.
Edit. Maybe not on the tuffy one. To expensive for me. Looks like the sweet spot would be the second one above and a HF hitch tray mounted above the box.
The amazon reviews indicate those options are exceedingly easy to break into. there's hopefully a balance between those you can open with a hammer and $1500 drawer.
Amazon used to have this one for $50. It has served me well, but no longer available.
GSC SL3500 Storage Locker
GR8TOPS shipped the LJ trunk, shipping weight of 24lbs. Hopefully it's more than a tin can, stoked to have the toolbox + SKIM additions to make me feel a bit safer driving around town.
Honestly this box is pretty flimsy (tin can). I would suggest adding reinforcement any and all places you can. I wish it was a bit deepe r as it leaves a lot space to pry off the tailgater. I wager if you gave me a decent flathead screwdriver I could reef it open.
