Hi, new member who needs some advice.
I know this topic is been discussed a lot, but my questions are based on the fact that I never found a topic that talks about my situation exactly.
I own a 97 TJ with UAE spec, ax-15/ dana 30 front with Dana 44 in the back, 3.55, 33s on 2.5-3 inch lift.
planning to do a 4.56 ring and pinion, here is my issue, I use my tj only lightly on the highway or in town, mainly it is driven in the dunes, since i will re-gear i like the idea of having a lunchbox locker or LSD since I won’t be able to reuse the carriers I have already, dunning is mostly done in 1-2-3 rd gears depending on type of the dunes, i don’t know if I should go with a front-rear lsd or front rear lunchbox lockers or a mix of both, and what parts will I need other than ring and pinion with a master install kit.
i have to order every thing from the states and I don’t want to miss a part then waiting for another month to get it, your help is much appreciate.
