Looking for fender replacement ideas
Mikebartusmc
Hello Jeep Forum
Looking to replace both front fenders on my 99 TJ wrangler
Im looking for ideas other than just stock fenders which is fine also
Feel free to chime in on what you've done in the past for front fenders, and web links greatly appreciated
Yes, I also need a new hood too :)
Thank you
mike
Mines got stock fenders but if I was to swap it would be Genright non high line like @Plumber1 has. They look great!
Thanks, the only issue is once you do the fronts it makes the back look bad. So then you end up doing the back also :ROFLMAO:. It's a typical jeep thing
Hello Jeep Forum
Thank you
mike
Stock would be your cheapest option because the section toward the rear of the fender is rotted out on the passenger side. The only other options are those that offer an inner fender with outer flare. Genright, Poison Spyder, Motobilt. et. al.
Genright aluminum (hi-fender or standard), Crawltek steel, Bushwacker pocket (plastic)
My passenger fender was rotted pretty bad . I had just enough good metal to install MCE’s . Happy with the results .
I went with Poison Spider Defenders up front and the matching flares in the rear. I opted for the aluminum version which I left unpainted since the raw aluminum is a fairly decent match for the bright silver metallic paint on my '04. Sadly, I don't think Poison Spider offers these in aluminum anymore, but I believe they are still available in steel.
Reactions: TheBoogieman
Are those the 5 inch version?
