The hard line in the pattern near the root indicates you could be a touch too deep but I would open the backlash to .010 and see what it looks like before moving the pinion.
They are the Dana svt gears and I was going by the service manual it says .005-.008 for backlash and for new pinion bearings 20-40inlbs. So which pattern looks better? The first two pictures or the second.
Ok I’ll give that a shot but it will probably be a couple days before I can get out and try it again. Thanks for everyone’s help so far I will post back with new results then.I would not try running those SVL gears that tight. They are not manufactured to the same standard as Dana OEM gears. Try adding .002 shim and keep the backlash at .008-.010 and see what it looks like.
Nope you missed the part where I said not to set SVL gears too tight and why not to.Did you miss the part where he said his second pattern was .005” BL and the third pattern was .008”? I’ve set up a few dozens axles and always shoot for .008”.
I also told him to increase his pinion depth as well and then shoot for .008-.010. I have had to run those SVL gears as high as .014 to get things to be happy. Focusing on the minimum specs with aftermarket gears can lead to a lot of headaches.You told him to run .008-.010”? He’s at .008”
